Best Wheel Cleaner
Adde
What is the best wheel cleaner around for use on all types of wheels.
Lately I have just been using normal soap and high pressure wash to get it off but I want to buy a wheel cleaner for my order with the guzzler package and QD.
An outstanding safe all wheel cleaner is>
autogeek_1929_45154657
An outstanding acid base all will cleaner is>
autogeek_1927_7800774
I just ordered some PB spray and rinse, myself. I've seen killr talk about it being the only one you could actually spray on and rinse off so many times... I had to try it.
I would go with p21s gel wheel cleaner. This stuff is amazing. If u buy the smaller bottle you get a sponge that ready helps get evything off. P21s is a little more expensive then alot of products but is well worth it. Its safe for all wheels and will get the worst brake dust off. I know my next order will have a 5 litle contanor of it.
I love P21S wheel cleaner myself. I use gel wheel cleaner. Another good choice is DP. But you can't go wrong with Wolfgang, or Pinnacle either.
P21S Gel, Poor Boys Spray and Rinse, and DP Wheel Cleaner are probably the best all around. P21S probably get's the nod as tops, but its the most $ as well. My wheels never get bad, I just spray with a citrus degreaser and rinse off, sometimes follow with soap and wash them but usually don't have to.
The Poorboy's spray is awesome! You spray it on and rinse, no need for scrubbing. However, it is powerful stuff that shouldn't be used everytime. For weekly cleaning I use the DP Gel. Great stuff! I just ordered the PS spray (not the gel) to give it a try.
Another nod for the DP gel wheel cleaner! I like it a lot and it works for tires too.
P21S --- Safe for all wheels, some agitation needed
DP Wheel --- Safe for all wheels, agitation needed, middle ground strength
Poorboys --- not safe on uncoated wheels, strong, citric acid based, follow directions exactly. Very nice product when used carefully. Strong !!
