best wool pads for polishing?
queens guy
looking to place a order and was looking for the best wool pads for polishing car? Any recommendations?
I have the Porter Cable Machine
Wool does not play well with Porter Cable machines
I suggest you look at the 5 1/2" Lake Country CCS pads
If you insist on foam, try the Lake Country THIN Purple Foamed Wool
I did get the micofabric pads but I don't like hoe the pads get app flat after 1 time use.
I think you are saying that the fibers on the Microfiber pads are getting matted down after polishing a section. This is normal.
In order for MF pads to work effectively, they need to be cleaned on the fly after each section is polished and before applying more polish and moving on to the next small section
Compressed air is best, but a nylon pad brush or a cotton towel also work just fine
Auto Geek Online Auto Detailing Forum - Search Results
