big trouble with 106 and sip today
mixxer
It was really humid but cool and i had all kinds of problems today. It kept caking up the pad and spitting off in balls of polish. I changed the pad twice and brushed the pad after each pass and nothing worked then i tried mixxing some optimum AIO thought that might help but nothing. It just wouldnt flash and i had trouble getting it off the paint even with the IPA wipe down. It was the only polishes i had with me so i stuggled all day long. Ive had it be tempermental before but nothing like this,,has anyone had any luck mixxing something in when this happens? I need to find another polish pair to use when something like this happens any ideas?
These polishes were designed to work by utilizing friction to break-down the diminishing abrasives, while in the controlled temperature / humidity environment (working temp range 60 – 800F (15-260C) of a vehicle manufacturer’s paint shop finishing line. It is possible to obtain results with Menzerna polishes utilizing a random orbital polisher; but these products were formulated for use with a high-speed rotary polisher that produces high friction and by using the correct pads. By using detailing products / tools in ways that they were not designed for could impact their ultimate performance and the results obtained.
http://detailingwiki.com/index.php5?title=Polishes#Speed
Alternatve polishes - 3M™ Perfect-It™ 3000 Extra Cut Rubbing Compound, 06060
3M™ Perfect-It™ 3000 Ultrafina™ SE (US) 06068 / Ultrafina SE (UK) 50383Use the ‘Slow Hand’ method for application; White polishing (softer less dense foam (70 PPI) with a light abrasive cutting action) followed by a Blue or Black Final finishing (100 PPI) LC CCS foam pad at 1100 RPM
yea i tried that to killr . I tried xmt pad pad it was bad nothing i tried made any difference at all.
It can be the weather but I find that alot of the time it is a dehydrated paint finish or working on new or near new waterborne paint finishes with sticky clearcoat
Kent
It doesn't really happen with the Makita, but it happens all the time when I used a PC. When I used the PC, I would shut the garage door and get the fan going to cool the garage.
Thus why I invented a new technology pre polishing preparation product that hydrates, moisturises, nourishes and chemically cleans the paint so it's ready to be polished
