Bird poop
sito
The glass hood of my suv has bird poop. I can't remove it over a year. It sticks like glue.
Is there a way to remove it?
Sent from my SM-G965W using Tapatalk
Are you saying it's been on for a year? Or you've been trying to remove it for a year?
Maybe glass roof?
If it's on the glass I would try scraping it off with a razor.
It stuck on glass over a year. I don't want to use wool steel to scrape it off since it will scratch the glass
razor blade and soapy water
Why would you let it sit and bake for a year?
Here's my tip/technique...
This article is from 2012
Get a towel completely saturated wet. Place the towel on the bird poop. Add some more water like this,
Take a clean microfiber polishing cloth, fold it four ways to create a thick, plush wiping cloth.
Wet the cloth with water until the entire cloth is saturated but not to the point where water is running down the hood. The idea is to have plenty of water present to soak into the dried bird dropping.
Let it soak for about an hour and then wash.
Unless the bird poop is a form of Krypton, it should wash off after water, (a solvent) has done it's thing and softened it.
What happens to your skin if you go swimming for an hour or sit in a hot tub?
It gets soft. Water softens. Water dissolves. The key is KEEPING the water ON the bird poop and you can do this with a microfiber towel.
Here's the original article....
Tips and Tricks: How to safely remove a dried bird bomb or bird dropping
Here's this technique used on a real, dried bird dropping. When I originally wrote this article I had to use simulated bird dropping.
Dried bird dropping
Allow some time to go by to let the water do it's work...
Let's take a peek...
Yep, it's liquid again...
Carefully scrunch the microfiber towel around the dropping and lift straight up...
Now dispose of the microfiber towel in a safe way...
That's how you safely remove a dried bird dropping... now wash the area clean.
Note: For health safety reasons it's a good idea to wear gloves when doing this.
Also, dispose of towel in a sanitary manner.
From 2017
How to safely remove a dried bird dropping by Mike Phillips
First - If at all possible remove a bird dropping as soon as it's discovered and before it can dry. The acid in the bird dropping can permanently etch the paint if not removed immediately.
If the bird dropping has already dried, then here's how you can safely remove it without scratching your car's finish. Note that dried bird droppings can contain abrasive particles in them so this is why you want to take these simple precautions.
A bird dropping can etch your car's clearcoat finish in under 5 minutes!
Now in the picture above it's apparent that the bird dropping has already dried like cement onto the paint. The reason you want to keep a spray detailer or a waterless wash in your car with a few clean microfiber towels (and also some nitrile gloves), is so AS SOON AS POSSIBLE you wipe off the bird dropping before it can etch the paint. If it does etch the paint, and that depends upon what's in the dropping, you'll likely have to use an aggressive compound to remove the etching. So it's better to be prepared and remove the dropping as soon as it's discovered then to let it dry and potentially cause damage.
What to do if you're too late and the bird dropping has dried...
Looking at the close-up of the bird dropping in the above picture you can see to try to RUBB this off the paint is probably going to scratch the paint. So here's the safe way to remove a dried, petrified bird dropping.
Step 1: Get a clean microfiber towel wet with water and place it on top of the bird dropping.
Step 2: Pour even more water onto the microfiber towel so that the towel is completely wet and saturated.
The secret?
It simple - the towel holds the water onto the dried bird dropping so the water can go do work doing what it does best and that is dissolving and re-liquefying the dried bird dropping. If you simply pour water or spray water onto the dried bird dropping it will simply run off onto the ground.
Step 3: After allowing the water to penetrate for a few minutes (or longer - you be the judge), carefully grab the dropping off the paint and lift the towel up and away. Don't wipe the bird dropping over the paint this could scratch the paint too.
Yuck!
There was some bird dropping residue in the seam of the mirror and for this I used a soft horse hair brush to get it out.
There you go... the safe way to remove a dried bird dropping. I would recommend sacrificing the towel and throwing it away as you don't know what kind of germs or disease the bird may have. It's also a good idea to wear some disposable gloves.
Mike's tip...
After removing the bird dropping, apply a light polish to the affected area to deep clean the paint and then apply your regular paint protection product. You can also use a one-step cleaner/wax.
This one is from 2010 - only I mocked-up the bird poop for this article. :laughing:
Copyright ©PBMA - AutogeekOnline.net® All Rights Reserved
If you have a completely dried bird dropping on your car's finish, and you DON'T have access to a water hose with free flowing water, then instead of wiping it off with a spray detailer or worse, scrubbing it off, do this instead,
  • Take a clean microfiber polishing cloth, fold it four ways to create a thick, plush wiping cloth.
  • Next, spray one side with your favorite spray detailer, the idea is to hyper-lubricate the entire face of one side.
  • Next place it onto the dried bird dropping.
  • Wet the cloth with water until the entire cloth is saturated but not to the point where water is running down the hood. The idea is to have plenty of water present to soak into the dried bird dropping.
  • Let the wet cloth stand on the dried bird dropping for 5-10 minutes.
  • Now, carefully enclose the wet-microfiber around the bird dropping using your hand and fingers , you're trying to carefully bunch-up the microfiber and then LIFT the bird dropping off the paint. Don't simply wipe the bird dropping over the paint.
Simulated bird dropping that has landed on the middle of the hood. In the real world, bird droppings contain Uric Acid and if not removed in a very short period of time they can actually eat through a coating of wax or paint sealant and etch or eat into the paint.
Simulated bird dropping using Meguiar's M205 with a little Wolfgang Finishing Glaze mixed on top for visual effect. Note, because the focus of this how-to article is on technique, we did not let the polishes dry as that's not a good practice but we think you'll get the idea.
Mist on a wet or heavy application of your favorite spray detailer detailer to hyper-lubricate one folded side.
Gently place the wet side of the microfiber onto the bird dropping.
Now add water to saturate your microfiber but don't add so much that you have water running off the hood. Allow 5-10 minutes to pass so the water can soak into the dried bird dropping in an effort to re-liquefy to make it soft so as to reduce the potential of instilling any swirls and scratches from dried bird dropping being rubbed against the paint.
Now carefully use your hand to scrunch or bunch up the microfiber around the now liquefied bird dropping and then lift the bird dropping up and off the paint. Don't simply wipe the bird dropping over the paint.
Give the area a final wipe using a new, clean fresh microfiber polishing towel using your favorite spray detailer.
Bird Dropping Etchings
If you notice any etching in the paint left by the bird dropping you'll need to use a compound, paint cleaner or swirl mark remover by hand or machine to carefully remove the etching and then afterwards polish the paint to a high gloss and re-apply your favorite wax or paint sealant.
If you need helps with removing an etching by hand or machine, post your question to the Autogeek Online Discussion Forum and we'll be happy to walk you through the process.
Products shown
Pinnacle XMT Final Finish Instant Detailer - 12 ounces
Cobra Arctic White Edgeless Microfiber Polishing Cloth
