Black Honda Ridgeline--detail
Bubbabuff
Nice to work with, found clear coat a breeze to cut through!
What products did you use? Also what was used to apply it the products?
Same process I used on an Infinity G35X I did last week
Products/process--EXTERIOR:
--Washed with C.G CW&G via foam cannon (first wash)
--Washed down with C.G CW&G via AG pro wash pail with grit gaurd (sheep skin mit)
--Amazing roll off to wheels and tires
--Separate pail for wheel wash/tire scrub
--Clayed with Wolfgangs poly clay/Optimum clay lube
--wet sanded scuffs with 1500 grit then with 2000 grit--then polished out with Menzerna SIP with orange pad. Amazing results
--Menzerna SIP with White PAD via PC 7424
--Alcohol wipe down
--Menzerna NANO with Grey PAd via PC 7424
--Alcohol wipe down
--Wofgangs DGPS, let cure for 12hrs
--Topped with Pinnacle Souveran paste wax
--sealed wheels with Poor boys wheel sealant
--Tires with Extreme shine
You got great results for effort you put in. Looks like you could dive into that black paint. Real nice work.
