Black truck help
Jrdriver
Ok first post. I have a black 2013 Silverado this is my first black vehicle and the paint isn't bad minimum amount of scratches and swirls and I'd like to keep it that way and improve on it now I use collinite 845 as my wax and it's great brings out a good shine the truck needs a clay bar but I also would like to do a polish and sealant on it for max protection I have always been a mothers fan but wI'll use whatever works what I need is options on a good polish sealant and clay bar nothing crazy just want good results and good shine and also has some buffer haze from the dealer detailing I'd like to get rid of any help?
Are you open to machine polishers? This will help determine the next recommendations.
If I had access I would be open but I currently don't so I'll be applying all this by hand
So fillers will benefit this situation ,I would clay truck gently maybe with a fine grade claybar and stick to 845 ,if you want to invest a day into this clay polish by hand then wax 845.you have limitations without a machine ,but you can yield favorable results by good old fashion elbow grease.
That's fine by me the work and time don't bother me what so ever as long as the results are good it's worth it but I thought I would need a fine clay but I wasn't sure so thank you for clearing that up for me
