Blackfire compound and finishing polish
KingStyles
I am wondering if anybody has any experience with the Blackfire compound and finishing polish. I want to remove swirls on my black lexus. I think I am going to use the blackfire line for the wax and was wondering how there swirl removers work. Would the Meguiars #105/205 combo be better? For light swirls and scratches, do you think they would come out with just the #205 polish or will the #105 polish have to be used? Thanks
There us a link on here that someone just did where they used m205 on a white pad for a black lexus and it came out amazing. I personally like to use all the same brands for detailing so that being said I would go with the bf line up. Never used it so can't comment on how it works. M105 &205 is an amazing combo but m105 can be very frustrating to use at first. Are you using a machine or doing it by hand?
I will be using a groit's. Since I posted this, I did see a review of the BF polishes used on a black suburban (i think) and it came out extremely well. It was a lot worse condition than my lexus. I heard that lexus black is soft so I want to make sure I dont over do it.
Hey KingStyles, Welcome. I understand what you are going through.. I recently joined and was a bit confused as well. I have a jet black BMW. From what I have found out, it has extremely soft paint. While I have not got to detail my car yet with BF. I will be using the finishing polish first with a white LC pad. If that does not work I will try another working up to an orange pad with it. I have seen a chart here that says that the BF compound has a good bite to it. From the mass amount of reading I have done, use the least aggressive method first. I will be doing this with a PC7424XP. (Don't know if it differs much from your machine.) Maybe others will chime in, but try the finishing polish first then work up to the compound if needed. Hope this helps.
You may find this helpful.
Blackfire SRC Polishes Remove Swirls & Water Spots w/Flex XC3401
