Blackfire Crystal Coating process
Rod73
Member
Sep 20, 2014
667
1
I was thinking of 1st applying Crystal Coat (Blackfire paint coating), then applying an hour later Blackfire Crystal Seal or Polymer spray. It's not with the intentions of adding anything but essentially to protect the coating from the elements while it cures.
I am curious about the forum members opinion on this plan?
Thanks
NO !!!!!
Let it sit in garage over night after coating. Next day, let it bake in FL sun.
Don't do anything to it for 7 days.
NO !!!!!
Does it have to cure overnight? I am planning on detailing my car at work, has a washbay. I can probably leave it indoors for 3 hrs. Is that not long enough for cure time?
You will be ok. Just don't wash or apply anything over the coating for around 7 days to let is cure properly.
Thank you! I just applied the wax on Saturday and its just stunning. My coworkers were impressed with the results and took me 20mins!
Is there a blackfire product I can use as a maintenance wax? Wet Diamond polymer spray or the Midnight sun carnabu spray? Could I use meguairs quick wax in between wwaxes or just stick with Black fire?
