How easy does it go on and off by hand? Does it stain plastic trim? Is it suitable for a new car?
I think I responded in one of the other threads: PBL Sealant will last 2x long at least, for double the effort (2 step polish and seal you mention). BF One Step has good abrasives and it’s hard to say whether your dedicated polish would correct better depending on paint condition and polish used. Let’s assume the dedicated polish and BF One Step correct the same if you maximize either one.
Thank-you for the response. Would BF all in one protect enough for Souther Florida, with 2-3 applications a year and BF sealant spray in between. I would like to avoid two steps.
don't most sealants like pinnacle black label require polishing first so they adhere to the paint?
what would be better BF one step and BF SiO2 Spray vs PBL sealant?
You’re asking some difficult questions given I can’t see your paint or know your preferred amount of effort and results... but I’ll take my best shot using assumptions from your earlier posts in case it is helpful in any way:
You’re a new member to this forum, I’m guessing this may be your first foray into these types/qualities of products. I think your vehicle is in decent shape based on another thread, but not brand new or perfect.
I think the route of BF combo is best for beginning. It’s less effort than a detailed two step. Do the One Step with orange or white pads. I’m sure the resulting surface will please you, even though there may be some swirls that you are OK with. Top every month or two with SiO2 Spray. Note in my early post to you I assumed you were talking about BF Synthetic Spray (non-SiO2). The SiO2 Spray will last much longer, it’s synergistic with One Step and will bead and shine lovely. You can keep applying the SiO2 Spray (assuming you like it) after every 2-4 washes/weeks and probably have non-stop protection until 9-12 months when you can decide if you want to re-polish/coat with One Step to refresh the finish.
Or at the time you think the finish needs a refresh and you’re ready to correct with more perfection in mind, this is the time when you can grab the proper swirl remover or finishing polish, do a two step carefully, taking as much time as you need, then seal it with a top notch finishing protection like PBL Sealant, which will last 6 months on its own and is resin-based, so I’m sure BF SiO2 would play well with it.
I thought it was easy to apply by hand.
