llively
Member
- Nov 15, 2015
- 39
I just applied coatings on two vehicles. Both were black Mercury Mountaineers. One vehicle I used blackfire crystal quartz. The another I used pinnacle V2. Before applying each coating I preformed the following steps to prep the paint.
1. Hand washed the exterior using DP car soap.
2. Used blackfire detail clay.
3. Applied pinnacle paint prep.
Pinnacle V2: I sprayed it directly on the paint and used an applicator pad to spread it. I then wiped it with a microfiber towel. It was very easy to use and the paint looked great.
BLACKFIRE Crystal Quartz: The last time I used this I was left with a sticky mess that took forever to level. This time I used only a couple of drops per section. It still dryed to a light haze but this time it was a lot easier to level. The paint looked great and it had more shine than the pinnacle.
I would love to know if anyone else had the same issue applying the crystal quartz? I will send an update at a later time regarding the durability for each coating. I live in Chicago so it will be interesting to see how it holds up.
