Blackfire Tire and Trim Sealant is available!
Elliot@Autogeek
BLACKFIRE Tire & Trim Sealant Now in Stock!
Restores, protects, and enhances exterior trim of any color!
BLACKFIRE Tire & Trim Sealant is the solution to an issue that plagues almost every vehicle manufactured in the last 30 years – dull, faded, and discolored plastic exterior trim. This thick, gel-like formula penetrates deep into the pores of plastic, rubber, and vinyl exterior trim, restoring the finish to factory-new condition. A traditional trim dressing might last a week or two if you’re lucky; BLACKFIRE Tire & Trim Sealant provides MONTHS of durable protection. Use it on tires as a long-lasting, waterproof dressing!
BLACKFIRE Tire & Trim Sealant is far more than a trim dressing. This polymer-based trim restorer forms a bond at the molecular level, restoring the surface while coating it in a durable, protective shell.BLACKFIRE Tire & Trim Sealant doesn’t wash off in the rain – it actually causes water to bead up like a wax! Treated surfaces will have a factory-fresh appearance – not a sticky, greasy mess like other so-called trim restorers.
This faded bumper is immediately brought back to life with just one layer of BLACKFIRE Tire & Trim Sealant!
Use BLACKFIRE Tire & Trim Sealant on moldings, bumpers, windshield cowlings, louvers, air vents, wiper arms, window trim, mudguards, side mirror housings, bed rails, door handles, and more! The durable UV inhibitors block the sun’s damaging rays, keeping your trim looking new for months.
BLACKFIRE Tire & Trim Sealant is a breeze to apply. Its thick, gel-like formula spreads evenly and dries completely. You can even BLACKFIRE Tire & Trim Sealant on hard and smooth surfaces. If used on hard, smooth surfaces, buff the surface dry with a clean microfiber towel. On tires, apply an even coat and allow to dry for 20 minutes before applying an additional coat. Apply multiple coats to tires if you want a glossy, shiny appearance.
_______________________________
BLACKFIRE Tire & Trim Sealant is as easy as wiping-on, and wiping-off! The trim on this Kia Soul doesn't look so faded or dull, but when you use the BLACKFIRE Tire & Trim Sealant you can see how much improvement is made!
BLACKFIRE Tire & Trim Sealant restores, protects, and enhances exterior trim of any color. This polymer-based trim restorer doesn’t contain any dyes or colorants. The formula creates a finish that looks and feels like the day your vehicle was new. BLACKFIRE Tire & Trim Sealant will not streak or wash off when it gets wet. The only maintenance required is regular washing with a quality shampoo, like BLACKFIRE Wet Diamond Conditioning Shampoo.
Restore, protect, and enhance your trim and tires with BLACKFIRE Tire & Trim Sealant!
Use BLACKFIRE Tire & Trim Sealant to both clean and restore the faded rubber on your tires quickly and easily!
Our Price: $28.99
BLACKFIRE Trim & Tire Sealant Launch Special - Limited Time Only!
Our Price: $46.92
Sale price: $31.99
BLACKFIRE Total Trim & Tire Clean & Seal Kit
Our Price: $98.94
Sale price: $69.99
