Blown 1934 Ford Pick-up - Show Car Makeover - Modeled by Kristin
As I type this it's 8:30am Saturday morning and the below street rod will be showing up any minute. I'm going to go roll out the floor mats to protect out studio tile floor while we work on this truck today and I'll try to post a couple of pictures of the truck after it arrives.
Hang tight...
Here go...
9:00am sharp we hear a very loud rumble outside the studio, I grabbed my camera, opened the garage door and took these shots of the 34 driving toward our studio..
We moved the 1934 inside and then wiped the finish down using Detailer's Pro Series Waterless Auto Wash.
After wiping the finish down we felt the paint using our clean hands and also using The Baggie Test.
The Baggie Test - How to inspect for above surface bonded contaminants
Both methods of inspecting the paint revealed a very clean and contaminant free finish so we skipped claying the paint.
Then I did my best to capture the fine or shallow swirls and scratches in the paint... hard to do with a camera but easy enough to see in person with your eyes...
Next we cover-up all the brightwork and there's lots of it. Take my word for it, when it comes to projects like this you don't dare get polish spatter dots on the engine or in this example the exposed running gear in the truck bed. It's not professional and besides that it would take you hours to wipe the little dots of polish splatter off.
The Autogeek Cover-up Towel is made from soft microfiber and can be washed and re-used. This come in real handy for covering up anything you don't want to get compound or polish splatter dots onto so you won't have to detail these areas with a toothbrush after the the wax has been removed.
The soft microfiber won't scratch paint or polished metals. Simple cover or wrap around components and then use a little painter's tape to secure them in place.
Here we've covered the polished aluminum gas tank and the chrome independent rear-end...
I got the other guys going with the Meguiar's, Porter Cable and Griot's Garage full size DA Polishers polishing all the major panels and set up the Griot's Garage 3" Mini Polishers for the smaller, tighter hard to reach areas.
Meanwhile I tackled the random, isolated deeper scratches, some by dampsanding with Meguiar's #3000 Finishing Discs and some just using the new Optimum 3" Microfiber Pads on a Flex PE 14 Rotary Buffer using Pinnacle Advanced Swirl Remover.
Continued...
After the radiator shell we moved to an area with some raised dimples on the paint, we sanded the area flat and then removed our sanding marks.
The above is what I call Surgical Rotary Buffer work which comes in real handy for working on small or thin panels or hard to buff areas. You need an extension for your rotary buffer, small backing plates and small buffing pads.
Trend: Backing Plate Extensions for Surgical Precision Buffing
On Autogeek.net
Optimum Optimum Double-Sided Rotary Adapter
2-3/4 inch Hook & Loop Rotary Backing Plate
The Polishing or Minor Correction Step
To remove any shallow scratches, scuffs and other imperfections we used the Porter Cable 7424XP, Meguiar's G110v2 and Griot's Garage 6" and 3" DA Polishers with polishing pads and Pinnacle Advanced Finishing Polish.
Here's Brian using the Porter Cable 7424XP with a 5.5" Lake Country Black Flat Foam Polishing Pad with Pinnacle Advanced Finishing Polish on the inner portion of the driver's front fender.
Here's Tommy using a Meguiar's G110v2 with a 5.5" Lake Country Black Flat Foam Polishing Pad with Pinnacle Advanced Finishing Polish on the driver's side roof.
Here's Andy with PC ready to tackle the passenger's side of the roof...
Teamwork...
Here's Kyle using a Griot's Garage 6" DA Polisher...
Using the Griot's Garage 3" Mini Polisher with a Griot's Garage 3" Foam Polishing Pad and Pinnacle Advanced Swirl Remover to remove any haze or swirls left by the rotary buffer step...
Andy knocking out the running boards...
Kyle getting the inside of the pick-up bed...
This is me working on the window frames...
Machine polishing the visor using the Griot's Garage 3" Mini Polisher...
Continued...
Cleaning an Optimum 3.25" Microfiber Polishing Pad using a Pad Conditioning Brush
Start out slow on the 1 setting which is 600RPM to spread the product out after using the 10 @ 10 Technique to pick up a bead of product
The 10 @ 10 technique for picking up a bead of product with a rotary buffer
Following up using a Porter Cable 7424XP to ensure any swirls are removed...
Machine Waxing - The Protection Step
After carefully wiping off all polishing residue we moved onto applying a coat of Wolfgang Füzion by machine. Two guys will use full size DA's and two of us will be using the 3" DA's...
I used a hot air gun to heat the outside of the plastic jar so I could slide the wax out as a single chunk of wax and hold it in a clean Microfiber Glove...
Then carefully swipe it across the face of a clean, foam finishing or waxing pad...
Tommy machine waxing the rear fender...
Getting Kyle set up to machine wax...
Kyle machine waxing the front fender...
The 3" Mini Polisher with a 3" Red Waxing pad works perfect on the front frame rails...
Lance has been playing Photographer all night and as you can see by the pictures he did a great job. Here you can see him checking out the 3" Mini Polisher to machine wax...
Tommy machine waxing the inside of the bed...
Machine waxing the paint in front of the engine...
Machine waxing the painted steel radiator tube...
f
Where we couldn't get a machine we used soft Gold Wax Finger Pockets which worked great...
Time to remove the wax
Microfiber Gloves help you to grip your microfiber towels and they also prevent you from putting fingerprints on the paint...
For the wax removal step we're using Super Soft Deluxe Green Microfiber Towels with Rolled Edges these microfiber towels are incredibly soft and gentle to highly polished paint.
End Results...
We didn't want to get the headers hot so we pushed it out after removing the coat of Fuzion, to avoid getting finger prints on the car everyone is wearing Microfiber Gloves...
Need to get this truck outside for a few mintutes...
So we can roll up the protective mats...
And then bring the pick-up back in to take some beauty shots...
Oh yeah...
Blown bad boy...
To get these kinds of results we machine polished this using Pinnacle Advanced Finishing Polish
Then applied Wolfgang Fuzion over it, which you see Kristin holding here...
Wolfgang Füzion is a true show car wax creating a clear, deep, wet shine on properly prepared paint...
Wolfgang Füzion is also super easy to apply by hand...
And wipes off super easy...
Kristin inspects our work using the Brinkmann Swirl Finder Light...
Looks like a polished gemstone...
And of course, the Transformation Team...
From left to right...
Tommy, Andy, Brian, me, Lance and Kyle...
:xyxthumbs:
Placeholder #7
This is a placeholder for the process pictures and write-up after we've finished this project. This way the pictures and information won't be on added pages later so anyone clicking on this link will see the entire project on the first page and at the same time people can post comments and questions...
The guys are hard at work out in the Show Car Garage! :buffing:
:righton:
Another fantastic make-over, on a fantastic vehicle, by a fantastic team!! Did I mention fantastic!
Thanks for sharing!
That is a nice looking truck? Is that special paint that was applied?
House of Kolor Candy Apple Red with a Gold Base
The finish was very nice when it arrived except just from wear-n-tear and repeated wiping there were the normal light or shallow swirls throughout the finish plus some random, isolated deeper scratches here and there. I machine sanded 1 scratch out and leveled another area with some surface texture and then removed my sanding marks.
The rest of the car we simply machine polished using DA Polishers, Pinnacle Advanced Finishing Polish on black Lake Country 5.5" Polishing Pads and then machine waxed the paint using Wolfgang Fuzion.
The paint has been waxed around 5 times since the owner took possession of the pick-up from the painter and polishing effectively removed all the previous coats of wax and any other light surface impurities plush the swirls and shallow scratches.
So it wasn't in horrible shape when it arrived but it was in need of a light polishing to restore the paint back to show car quality.
On page 37 of my how-to book, I list 11 paint condition catagories...
The paint on this custom hotrod pick-up fell into category 2. Excellent Condition we restored it to category 1. Show Car Quality.
I did my best to capture the light swirls, scratches and RIDS but I have not looked through all the pictures taken with my camera today. My norm is to always document as best as I can the defects in the paint before we start machine polishing but until I start going through the pics I don't know if captured them or not.
Wow that truck (and the model too! ;)) is looking nice!!! The paint couldn't get any better than where you brought it to. Great job guys! Wish I lived in FL!
That's the best looking car, urrrr truck to ever hit the AG floor IMO
The swirl girl is pretty sweet too!!!
Awesome job. That is one amazing truck. I absolutely love the color. You can tell the owner appreciates keeping it looking nice because from the before pics it wasn't in bad shape overall
