BMW i3 OLIVE LEAF TANNED LEATHER treatment?
Fredr500
My new BMW i3 has OLIVE LEAF TANNED LEATHER, is that any different than other car leather?
I was about to buy the Wolfgang Leather Care Cockpit Kit but I saw this:
Wolfgang Leather Care Cleaner should not be used on napped leathers like suede or glove soft leathers.
So is the Olive Leaf Tanned leather a glove soft leather or can I use it the Wolfgang kit on it?
Thanks.
Hi Welcome to AutoGeekOnline! Congrats on the new BMW i3.
I doubt many have experience with this new tanned leather offered from BMW.
IMO, I would start off by asking the dealership where you bought it what to use. I know BMW has their own line of car care products.
Or maybe someone from PBMG may be able to help out.
Here's what the owner's manual says:
Leather care
Remove dust from the leather often, using a cloth or vacuum cleaner. Otherwise, particles of dust and road grime chafe in pores and folds, and lead to increased wear and premature degradation of the leather surface. To guard against discoloration, such as from clothing, provide leather care roughly every two months.
Use leather care products; otherwise, dirt and grease will gradually break down the protective layer of the leather surface.
Suitable care products are available from the service center.
And of course searching their website shows NO leather care products.
I did ask their detailing crew what they used on the i3, after a deer in the headlights look I got "the same thing we use on everything."
I'll watch for Wolfgang products to go on sale and order the kit.
It looks like what is different about your leather is the method with which it is tanned, but otherwise it is simply leather.
The company later confirmed to leatherbiz that the tanning process in question is Wetgreen, a tannage based on residues from the olive oil industry, principally the leaves of the olive trees, which are traditionally discarded and burned. It produces a leather with a shrinkage temperature of about 76 degrees Celsius; it’s suitable for retannage using vegetable or synthetic tanning material. No aluminium, chromium product or salt is necessary.
BMW interior award spells success for olive-leaf tanning process - leatherbiz.com
I would treat it as you would any leather, use a product for leather care, such as Lexol, Leatherique, or many other brands found here.
OP.. Please do not use Lexol on your leather.
Nor is there a need for Leatherique on your new leather.
I would recommend you go with something such as Leather Masters light Cleaner and protection cream.
You could use Pinnacle Black Label Leather Cleaner and Leather and vinyl Coating
Carpro Inside Leather and Interior cleaner and Cqauartz Leahther Coating is also another great option to name a few.
Thanks. I'll be watching for Wolfgang Leather Care Cockpit Kit to go on sale.
What colour is your leather?
I suspect that Olive Leaf may be a colour reference rather than a tanning process!
Protect from new
Maintain with a leather 2 in 1 cleaner and protector
Deep clean with a water based foam cleaner once or twice a year defending on usage
This will keep your leather looking good and prolong its life
Avoid Lexol which was made for saddles and anything containing oils or waxes as these are counter productive
Hope this helps
Judyb
It is black or brown. It is a tanning process using used olive leaves, it is supposed to be more environmentally friendly.
Thanks for the advice Judy.
In that case it would be classed as a veg tanned leather
Does the leather absorb moisture or does it sit on the surface - this will determine whether it has a coated surface and form there how it should be looked after
Cheers
Judyb
Cheers
Judyb
Water sits on the surface.
Cheers
Judyb
Its gonna be a coated leather.
Does anyone know if uncoated leather is used in todays luxury vehicles? Doubt it but just curious.
So if it's coated can I just use any auto later detail? I'm thinking either the Pinnacle or Wolfgang kit.
If the moisture stays on the surface you have a finished leather however the leather was tanned.
Protect with a quality water based protector (avoid anything containing silicones)
Maintain with a cleaner/protector regularly to remove contaminants form the surface
Deep clean once or twice a year
These 3 simple steps will help keep your leather in good condition snd prolong its life
Please avoid anything containing waxes and/or oils (conditioners) as these are not required and will be counter productive simply attracting more dirt.
Modern car interiors may be trimmed with a variety of leather finishes including Aniline and Micropigment although the majority are standard pigment coated leather
It is always important as a detailer to know and understand leather and how it is finished so the correct procedures and products can be used to ckean and restore
Hope this helps
Judyb
I think there are a few. Ford used to put it in the King Ranch Editions of their trucks/SUV's. While I've never been close enough to tell for certain, I wonder if there aren't a few European high end cars like Ferrari, Bentley's or Roll Royce with that type of leather. I haven't had close access to any of those for a while to still be certain.
Hope this helps
Judyb
So the conditioner products touted here are to be avoided
Pinnacle Leather Conditioner nourishes leather with a rich formula of lanolin and natural oils. These oils quickly absorb into the hide leaving a non-greasy, satin finish that actually repels dirt and moisture. A subtle fragrance compliments the leather’s natural aroma.
But this is OK:
Leather & Vinyl Cleaner will remove just about any stain from leather and vinyl. Natural citrus cleaners penetrate deep into every pore to gently lift out dirt, grease and oils. The toughest stains wipe away leaving only a fresh lemon scent.
What about Leather Honey products? This is all they say about ingredients:
While we cannot tell you what is in Leather Honey Leather Conditioner (it’s a closely-guarded family secret!), we can tell you what is not in it – any sort of toxic ingredients.
Chemicals have a tendency of doing more harm than good and we decided at the very beginning that the health and safety of our customers was too important to risk. We find it disappointing that many companies out there manufacture various formulas of leather conditioner without the same approach.
Leather Honey was created many decades ago, before many of these new popular chemicals began to find their way into our homes. Our high-quality ingredients are still the same today as they were in the 1960s. Over the years, there have been cheaper but risker ingredient alternatives that have appeared and we have just simply said – no thanks. Our non-toxic Leather Honey is perfect just the way it is.
Both people and animals are in regular contact with leather. We wear it, sit on it, play with it and sleep on it. This is all direct contact with skin. Does everyone get sick from toxins? Of course they don’t, everyone reacts differently to that type of exposure. However, we believe that the risk of even a single person experiencing health problems related to a chemical is too great.
Our family recipe and high-quality, premium ingredients make us the number one leather conditioner on the market. You can trust our product for making your leather look and feel like new.
P.S. Leather Honey is free of animal products, silicone and solvents as well.
The more I "learn" the more confuddled I get.
More research, got this from the Lexus forums. It appears that Leather Master Soft cleaner (or strong leather cleaner) and their Protection Cream meet the requirements and are highly recommended. And they are affordable. And available on Amazon Prime.
So...
You'll believe them Lexus folks...
instead of me?
Well! I'm miffed, to say the least! :laughing:
Bob, that's how I found the Lexus guys, searching on your input. Sorry for not crediting you too.
