TiCaLLioNStaLLyN
- Apr 6, 2016
- 72
Hey guys.
Mentioned this on another guys mf pad thread issue but had no response. Dont want to jack his thread.
So I finally got around to using my g21 for the first time and also my first time polishing a vehicle. So far have just done some compounding with menzerna 400 and boss 6.5 orange correction pad.
I'm doing this at a very casual pace as I don't have much time after work but winter is coming fast north of the border haha. So I'm just doing a panel here and there etc. It's an old 91 pathfinder I'm using for Learning.
So I've used this pad, pictured, for two sessions of 400 at speed 4-5, primed my full pad face with product and a squirt of luber. I've been doing 2 sections/4 passes, with light pressure, then using a conditioner brush....2 more sections and 4 passes each section again, then change...or bed in my case.
Washed pad right after use with griots micro cleaner in warm water and wrung by hand. Left to dry overnight. Did same again following night in terms of process.
After cleaning again I really noticed the separation of the pad to the hook and loop backside.
I stayed away from badges but around some window trim, i may have rubbed on the tape covering, slightly.
Is there something wrong in my process? What can I do
Now I ha e only used the one pad and tonight have a few hours and will be going through a few pads trying to get it done. I am worried about ruining my brand new pads now. I dont know what else to change other than speed, but if I got to run at 4 or less how am i going to achieve correction etc.
I did notice the boss felt pretty damn warm. Does heat transfer from machine into pads etc
Pics are all of different sections in pad, not same spot. The bow look in pad happened last night when drying because of the thin railing it was drying over. Dumb on my part.
Thanks for input
Sent from my SGH-I337M using Tapatalk
