Bought a new G110v2 and have questions about buying non-Meguiar's pads.
I have the W68DA backing plate.
The G110v2 I bought came with three (3) Meguiar's 7 inch Softbuff 2.0 pads. I chose W7207, W8207, and W9207
I will be polishing with the Meguiars #105 and #205 and/or Ultimate Compound and Ultimate Polish...
I watched the DVD with Mike Phillips; thanks by the way!
It appears as if it would generally be reasonable to start with a polishing pad (i.e. Meguiar's Yellow one) and some #105 or UC then follow-up with a Finishing pad and some #205... or UP... keeping in mind to try the least aggressive product first, of course.
Now I want to buy more pads. Which Lake Country ones will work with my backing plate?
Do I need to buy another backing plate like the W67DA?
Being the W68DA (backing plate I have), my assumption is that I need at least a 6.5"pad right but even then I need to be careful because the pads may be recessed???
Obviously, a 5.5" LC pad would not fit my W68DA backing plate because the plate is about 6" in diameter.
Will LC 6.5" pads fit the W68DA plate?
