Not if it is a “Chlorinated” brake cleaner!!Can I use brake cleaner
for removing wax?
With me considering polishing process(es)Also what do you think about using
Extraction naphtha for wax removing?
carnauba wax really removes itself under direct sun? Why?
Hello
Can I use brake cleaner for removing wax?
Also what do you think about using Extraction naphtha for wax removing?
Hello
Yes. It is all for the same car.
I asked about wax removing because I polished the hood and put wax on it. As you know from another thread the polishing was not so good becasue left very scratches. So I need to correct it.
I don't want to polish this element because I heard that old wax can clogg up my polishing pad.
Hello
Can I use brake cleaner for removing wax? Also what do you think about using Extraction naphtha for wax removing?
When I read through your posting history I find it confusing all the "various" questions you ask.
I figure you're truly here to learn and need help or you're trolling this forum.
:dunno:
mike- this is not worth you time but I understand your position needs to answer…
a rediculous question…Im waiting for the next question: “can I use a flame thrower for getting rid of wax?”
I use wax and grease remover ...it's what it's designed for and doesn't knock you out like brake cleaner
Kind of a troll-like question/thread IMO.
Who in the hell would spray brake cleaner on their paint?
I think this one needs to be interned into the thread graveyard...........
