Coach Steve
- Jun 12, 2013
- 410
So, as the title says, I broke the neck of the bottle to my foam cannon again due to carelessness and not paying attention. I left the bottle sitting upright with the foamer attached and full, all ready to attach to my PW and the hose shifted and knocked it over breaking the brittle neck.
This is getting expensive!
Now, I don't know if you've ever noticed but the bottle looks a lot like the big bottle of Tresemme shampoo/conditioner - I mean A LOT!! Turns out, I just happened to have said bottle in my bathroom. So, to satisfy my curiosity, I retrieved the bottle, unscrewed the broken piece of neck out of the foamer, and proceeded to attach the foamer to the Tresemme bottle and by God, it's a perfect fit!
My thought process began to run through the path the water takes after leaving the pump and I immediately thought the thinner, more flexible shampoo bottle wouldn't withstand the pressure of the water flowing through it but, I was wrong. It worked like a charm!
So, if you should break the neck on your bottle, you can use a Tresemme bottle as a replacement until you get a real bottle.
rops:
