So I am about done wet sanding the fresh paint on this Mustang and am ready to purchase a buffer. I'm thinking I'm going to go with a Dewalt rotary as they can be had for very good prices and its a quality piece. I know rotaries are touchy but if I screw it up I will just paint the panel again..lol and hopefully learn something. This Mustang has a ton edges and corners so I would think 4 or 5.5 inch backing plates. Would you recommend flexible backing plates? Should I use a wool pad for the first cut or an orange foam pad? Is there a preference? Do I need both? After reading a lot of the posts it appears like Megs 105 and 205 is a safe bet Any other suggestions? If I wasn't so damn poor Id buy a couple of everything and a D/A polisher but that's not going to happen... Any suggestions would be greatly appreciated. I also have an old Rambler getting paint next week so would it make sense to purchase a larger backing plate since that car has a lot more large flat surfaces or stick with the 5.5's?
Thanks!
Thanks!
