jeffindetail
- Oct 24, 2017
- 26
Working for a dealership, I get this problem on a semi regular basis. On the lighter end of the scale, we had a pretty bad ant infestation in the grass over the summer. Pretty much every vehicle parked along curbs with grass eventually wound up with ants in them. On the more serious end, is a German cockroach infestation. Oddly, most of the roach vehicles aren’t are from customers who aren’t even in for that issue. They’re usually in for mechanical issues, but the mechanic refuses to work on them until the roaches are removed and unfortunately it becomes my problem.
Removing the ants is fairly easy, I use a non-odor, no mess fogger from the hardware stores. I set it off upright, on the floor, let it work for at least 2 hours and air it out just as long. Then come in and vacuum up the ants. The German cockroaches are a nightmare. First of all, they’re there because the vehicle is absolutely disgusting. Clean cars don’t accidentally get a German cockroach infestation. The best way to go about it is a complete interior removal and cleaning. Also a complete cleaning of the exterior, engine bay, and undercarriage. Foggers are needed and will kill them, but they are so resilient that during fogging, they’ll exit the vehicle and hangout in the exterior until the fumes dissipate. If you can somehow tent the vehicle, that may work. As for me, most of the time there isn’t time or money for this much work. So, what we usually do multiple foggings, followed by an interior detail and that’s followed by more foggings. Sometimes you get them completely. Sometimes you just reduce the population and that’s good enough for the mechanic to do what he needs to do.
Does anyone here deal deal with this regularly? Do any of you just walk away from these jobs? If you do tackle these jobs, what methods do you use?
