If it is not exactly the same, they are identical. Yellow foam on a Shmitt works just fine at removing bugs and tag. be sure to use soapy water for proper lubrication, otherwise you may get a lot of swirls.Jimmie said:Anyone know if that yellow pad in a ShMitt is the same material as the Pinnicle Bug & Tar Pad ? Pictures sure look similar.
