PinnacleAutoCT
- Sep 28, 2014
- 110
Hey guys, I haven't been posting much due to it being the busy season in CT. I figured this pair of vehicles from yesterday would be of interest to the forum, so here they are:
First up is the Avalanche, this one is a 2007 with 51k miles. It was purchased last fall with 37k miles, and had only been quickly detailed by the dealership prior to delivery. The goal here was to quickly clean up the inside and outside while making it easier for the owner to maintain its appearance in the future. It had recently seen some long trips to the shore, so the front end was splattered with bugs, while tar and general road grime covered the lower panels. The rear wheels had heavy accumulation of baked-on brake dust due to incorrect pad selection (the owner swapped out the pads to alleviate the issue).
Before:
Note how dull the paint looks, and the visibility of the bug splatter even from a distance:
DSC04163 by Mike Donoghue, on Flickr
DSC04178 by Mike Donoghue, on Flickr
DSC04189 by Mike Donoghue, on Flickr
Close-ups of the bug splatter, here CarPro Tar-X would be used as a pre-soak to loosen the bugs:
DSC04164 by Mike Donoghue, on Flickr
DSC04174 by Mike Donoghue, on Flickr
Tar and grime covered the lower panels, CarPro Tar-X and Clay Magic medium clay would remove the accumulation:
DSC04173 by Mike Donoghue, on Flickr
The dealer had "wheeled" the entire paint, meaning they sloppily polished the entire body with a rotary, resulting in these swirls:
DSC04169 by Mike Donoghue, on Flickr
DSC04185 by Mike Donoghue, on Flickr
The front wheels had some accumulation of brake dust:
DSC04172 by Mike Donoghue, on Flickr
The rear wheels were much worse in the brake dust department, Sonax Wheel Cleaner Plus would be used multiple times to clean them:
DSC04176 by Mike Donoghue, on Flickr
DSC04181 by Mike Donoghue, on Flickr
Following the wash and decon steps mentioned above, the body was polished using the Rupes 21 and 75E using Lake Country white foam polishing pads and HD speed. This combo deep cleaned the paint and removed the rotary holograms, plus some of the marring, which was all that the owner was concerned with. Following this the paint was sealed with CarPro Reload, and the tires were dressed with 3D Ultra Protectant.
After:
DSC04213 by Mike Donoghue, on Flickr
DSC04214 by Mike Donoghue, on Flickr
DSC04216 by Mike Donoghue, on Flickr
DSC04206 by Mike Donoghue, on Flickr
DSC04207 by Mike Donoghue, on Flickr
DSC04219 by Mike Donoghue, on Flickr
DSC04222 by Mike Donoghue, on Flickr
The owner was very happy with the final result despite the very basic process that was performed. Please note that the trim is untreated in the pics, this is because the owner had a product (a dye of some sort) that he wanted to apply himself.
Before:
After:
