If no one has Welcomed you, let me be the first!
:welcome: To Autogeek Online!
Take the money you'd spend on a thickness gage and buy some good equipment and products.
Kit Page
Car Care Kits, Car Care Cleaning Kits, Complete Detailing Kits
Decent kit
Flex Kit
If I were in the market for a kit this would be the one I'd choose.
Porter Cable style machines
The 6 1/2" diameter pads a
Porter Cable 7424 in my opinion pushes the limit of the machine and this could be part of the problem.
I have the
Porter Cable 7424 and found a world of difference when I decided to try
Lake Country 5 1/2 diameter pads.
The
Porter Cable 7424 style dual action polisher should come standard with 5 1/2 inch pads and corresponding backing plate.
Pads & Friction
The size or surface area does not directly affect the frictional force between two surfaces until downward force or pressure is applied. Reducing the pad size will only improve the mechanical efficiency of the machine.
The motor of your polisher produces some amount of power. The larger the pad surface area the harder the motor must work. Now, most will say "it's only 1 extra inch", but when it comes to surface area and friction your really talking about an additional 10 square inches. Now take a look at the difference between the 5 1/2", 6 1/2" and 7" pad...........Size does matter!
Surface Area - 5 1/2 pad = 23.75 in²
Surface Area - 6 1/2 pad = 33.18 in²
Surface Area - 7 pad = 38.484 in²
There is a direct relationship between the pad surface area and the polishers ability to transfer adequate power to the pad improving it's overall performance.
Lake Country Pads
Lake Country 5 1/2 x 7/8 inch Beveled Edge Pads 6 Pack, foam pad kit, build a kit, buffing pads, curved edge pads
Backing Plate
lake country 5 inch backing plate, 5 inch backin plate, 5 inch hook and loop backing plate
Paint Perfection
Menzerna Bundle
Menzerna Power Gloss, Power Finish & Super Finish Bundle, Menzerna Polishes Combo, Nano Polish, Power Finish Polish, Power Gloss Compound
Many really like the new
Meguiar's Microfiber Dual Action Correction System
Meguiars DA Microfiber Correction System 5 Inch Starter Kit, paint correction kit, dual action polishing kit
