C6 swirl removal
44Doug88
Any special instructions on removing swirls from a C6 Vette as opposed to a vehicle with a metal body?
The panels will heat up faster because of the fiberglass so prepare for that (dusting) what are you planning to use as far as pads/polishes/machine?
I'm going to use PC buffer and Pinnacle swirl remover kit.
ok, I haven't used pinnacle polishes but if its a swirled it might be a challenge.. especially with a PC. Take your time and be patient would be my advice.
A Flex and some Menzerna FG400 would work wonders for the vettes finish.
Do you happen to have any microfiber pads on hand? If not getting some would be my suggestion :xyxthumbs:
What type and size pads do you have for the Porter Cable?
What are the potential problem using a PC?
Microfiber pads for......?
The PC is not great with the 6 1/2" pads. It will work, but is just a bit slower
The dimples in the CCS seem to help a little vs. Flat Pads
Mark your BP and make sure it is spinning at all times to maximize the cutting ability of the machine
Specifically, the thin Meguiar's DA Microfiber pads work well with the PC
Because they are thin, they transfer more of the motion of the machine to the paint
I really like the 3" DAMF Cutting pads on a PC for tight areas, like pillars and thin bumpers
Take lots of Before & After photos including close-ups and Sun Shots
Would it be a better idea to return the PC and get the Flex?
The PC isn't a bad machine but it's correction power is limited compared to the Flex. This will be especially obvious on the Vette's rock hard clear.
IW
IW
Took the words right out of my mouth err.. Fingers.
That's really up to you but I had a PC when correcting my c5zo6 and I decided to buy a flex as well and haven't looked back. I only use my PC now for small area correction with my 4 inch pads
Well I'm beginning to think I should return the PC and do more research. I'm getting more confused on what I should use. I live in Ohio and probably won't be using a buffer much until spring anyhow.
I believe part of success is being confident in the tools being used and right now, I'm not feeling it.
Too many options I guess.
Thanks to all that responded and I appreciate your input.
Let us know what you decide and be sure to ask questions if you're unsure about something! We're here to help :dblthumb2:
Hold on a minute...
The PC will be the "safest" polishing tool for you to use on not only your Corvette, but any other vehicle as well.
Remember to do the obligatory "test spot" in order to "dial-in" the products/tools. Going with a 5" Backing plate and thin Buffing pads will facilitate your swirl removal...while using swirl removing liquids.
:idea:
Let me suggest that you call Nick at AGO.
He'll know exactly what you will need...to succeed!!
