Call me stupid......
Burnt350
Dilution ratios confuse the heck out of me. Just got some D101 and it says it can be diluted 10:1. How do you calculate how many ounces of concentrate : ounces of h2o?
10:1 means 10 parts water to 1 part product. part means units of measure i.e. gallons, ounces, lbs, etc. If you mix 10 ounces water to 1 part product, you have a quantity of 11 ounces mixed 10:1. there are 128 fluid ounces in a gallon. to mix a gallon of product at 10:1, you would mix approx. 11 ounces of product ith the remaining quantity being water.
1st off you are not stupid....LOL! If it's too complicated for me (most of the time...LOL) I just buy the product already made for the detail purpose.
When it comes to washing and rinseless wash I usually put in the amount "I Think" is good enough! So far I have not blown anything up...yet!!...
greg in ga really is messing with my mind with all the numbers!!....Have a great day!
Don't overthink it. If you have a 32oz bottle put 3 oz of D101 then fill the rest with water close enough.
The easiest way is to add the two numbers together in the suggested ratio, e.g. 4:1=5, then take that number,5, and divide this number into how many ounces your bottle is, and that is how many ounces of product you'll mix/use.
32 oz bottle
Mix 3:1
Add3 &1=4
32 divided by 4=8
So, 8 oz of product will be mixed, and the remaining 24 oz will be water.
Its the other way around...not to confuse the heck out of things its 1 part product to 10 parts water
Get the bottle for D101. It has the markings on it.
This is correct. After filling literally thousands of bottles I've never had one yet explode for being slightly above/below suggested dilution ratios.
No cannot call you stupid!
Try this chart: Dilution Chart
I've printed this chart out, included it in my 3 ring binder, on detailing for quick & easy reference.
Dilutions & recipes can be deceptive, example
1 gal H20, + 1/2 cup bleach + 1/2 cup vinegar
is not equal to pouring about a gallon of water then adding the remaining items.
What that recipe yields is: 1 gallon + 1 cup, which could be mixed in a bucket & then poured into a gallon jug. The remainder well...
This is something many get wrong & wonder about results.
If its 32oz and u want 10:1 just do (32/11=2.9oz) 2.9oz solution then the rest is water or if u want 5:1 in 32oz bottle just do (32/6=5.3oz) 5.3oz solution rest is water, get it? Its really easy
32 oz bottle
Mix 3:1
Add3 &1=4
32 divided by 4=8
This is what I was taught. But some companies turn their numbers around like 1:4 , why I have no idea.
