CamSpray connection question
innova
Hey all,
Question for the Cam Spray foamer owners. I've attached a photo to simplify it.
Basically, Part 2 only seems to want to go into Part 1 (connection A) about halfway. I just wanted to know if this should be expected to go all the way in before I really torque down on it. I do notice some white film in the threads of Part 1, not sure if it's residue or some kind of loctite.
Thanks in advance!
Hey all,
Thanks in advance!
If you look at the adaptor it is a tapered fitting it will only go in so far.I would use some plumbers tape in it first
Harley Guy is right on it ! TEflon Plumbers Tape is the residue you see. Use three wraps in the oppisite direction of how it screws in. But the 1/2" width for this fitting. There should be about 4 or 5 threads showing when it is in all the way.
Thanks guys, I didn't know tapered fittings existed, much appreciated !
Guess I have been away from here too long. I get that this is to spread a nice layer of soap.... but where can i get one? Did a search here and its not sold here.
