Hey guys I know prob a dumb question but I put these in my cart every order than remove them because I really can't justify or figure out what they do. What the diff from say a LC flat pad ?
great sounds like ill finally order some
Has anyone tried them on a rotary?
nice. what steps did you use? did you use a DAI couldn't be happier with the results from Surburf pads with headlights. Also great with leveling scratch out and removing heavy swirls.
also what size surbuf did you use on the headlights?
on the DA? Also what compound did you use?i used the 3" surbuf which i had to order direct...
