wow how was that bmw done?
This was actually an extreme makeover that included removing RIDS using a technique I call feathersanding.
Other guys before me may have done this, hard to tell the Internet wasn't around till the mid-1990's but I'm probably the first guy to document it.
Know one ever showed me how to do this, I just used common sense and figured it out on my own with the idea being to only remove paint surrounding the RIDS, not using the Bubba method of compounding and compounding the entire hood, or sanding and then compounding the entire hood.
I prepped this BMW for the 2002 Bimmerfest as a project I just came up with just for fun. I was still the
new guy from Oregon at Meguiar's at that time. Now I'm the new guy from California at Autogeek. There's still threads about it on the Bimmerfest forums that date back to 2002
Here's one thread on MOL where I go over much of the technique.
Feathersanding
Quote:
Originally posted by red vette
thanks Mike,
My mistake,yes I have been using scratch X for awhile now on all my vehicles,not having any luck though removing a couple light scratches,cannot be felt with finger nail,but repeated tries with scratchX still has not removed them,any idea's?
John
Hi John,
If repeated applications of ScratchX is not removing the scratches in your finish, this tell me two things,
- Your paint is very hard.
- It will require a machine applied Professional Line product to remove the scratches.
The way I usually remove is with an advanced technique that I call
Feathersanding, which requires the use of Meguiar's
Unigrit Finishing Papers and a rotary buffer.
Experience helps a little too! Below are some pictures from a
Side-by-side, before & after demonstration I did for the 2002 Bimmerfest in Santa Barbara. First I used a rotary buffer to buff out one half of the car and remove all of the light scratches. Next, I took little postage size stamps of Nikken Finishing Paper and sanded each individual scratch till it had been removed. Next, I used a compound to remove my sanding marks. The results were a scratch-free flawless finish on a 1991 e34 BMW M5.
How To Remove Random Isolated Deeper Scratches using the Feather Sanding Technique
Before
I compounded the entire finish before starting the below process to remove the shallow scratches and expose the deep scratches.
Process
Random, Isolated, Deeper Scratches, (RIDS), can be removed, but it is an advanced technique that takes skill, patience and the right products to accomplish successfully. (A little luck helps too!)
Do you own a rotary buffer and do you know how to use it?
There's a bunch of threads on it each with more or less information and each with more or less pictures. Just do a search on MOL using the words Bimmerfest or feathersanding. Sometimes I think I spell feathersanding with a hyphen like this, feather-sanding, I'm not sure as I made up the word to describe the technique.
The original thread was hosted on the ShowCarGarage.com forum before MOL existed. Sorry to say the original vBulletin ShowCarGarage forum is now cyber dust.
The picture was used for SwirlX as a 'picture type' of what SwirlX can do, i.e. remove light swirls. I'm not sure it cold have actually worked for the initial cut on the hood which I did with M84 Power Cut Compound with a W-7008 Foam Cutting pad using a rotary buffer. The picture is just to get across to Joe Consumer what the product is used for.
I did the first side of the hood and then put the car on display at the 2002 Bimmerfest. Then after the Bimmerfest I did the passenger side of the hood.
Both sides took about 12 hours of some very careful work as this was the original clear coat finish on this 1991 e34 BMW M5. Keep in mind when I did this work on this car's paint, it was already 11 years old.
I would like to do another one for the Autogeek forum but I need a black car in really bad shape like this BMW was in and the owner has to pledge to take care of it after the work is done or it will just be for nothing.
Any takers?
Over the years I've received a lot of e-mails from
around the world asking me how I did this? :laughing:
