It's my understanding you can top OS. I haven't used mine yet.Conor said:something like wolfgang or z-cs or opti seal?
or is that a nono
it just seems these wipe on wipe off products are easier? maybe it just sounds that way
XMTFG has a cleaner in it. It might remove some OS.Conor said:so i can do in this order?
XMT swirl remover 2
XMT swirl remover 1
OS
XMT Finishing glaze?
True, but it seems you can apply OS over a nuba.bambo2888 said:You CAN use a sealant over the XMT instead of the glaze. You can't however, put a sealant over XMT glaze because the glaze has carnauba in it, which will not let any sealant bond to it. You will end up applying and wiping it all off, wasting the sealant.
If you want to use a glaze, use the WG Finishing Glaze because it does not contain any carnauba. Then, you can top that glaze with any sealant and then any wax. This is your best choice for protection, longevity, and looks.
Also, you can't glaze over a sealant. The glaze is meant to stick to the bare, cleansed clearcoat, not to a synthetic sealant or carnauba wax.
Conor said:I plan on following up the glaze with a coat of Pinnacle Signature II wax
