Can I use Cleaner wax for removing swirls from ceramic coating?
KYL
Hi Mike , Big fan of you and new member to this forum..
I coated one of my relative car with Carpro UK 3.0 coating.After 6 months , when I checked ceramic coating , I found that there are swirls marks and some water spots on coating. Coating is now only 6 months age and how do I clean out those swirls and water spots? Can i use cleaner wax?
or Essense Plus from Carpro?
If i use cleaner wax , swirls might be gone but does it effect ceramic coating? or what should i do?
Thanks
Essence Plus with CarPro Gloss Pad is the only thing you can try that won’t remove the coating, a cleaner wax with polishing pad would likely remove it or severely degrade it.
Keep your expectations low with Essence+ though, in my experience it never fixed anything.
If you have coating left from 6 months ago you might as well polish the affected panels and coat them again.
^^ 100% this. Essence Plus is pretty much useless. I only use it to remove the rare high-spot I might encounter. IMO the best course of action for you is to re-polish with Essence and re-coat the vehicle.
You could try a waterspot remover like CarPro spotless for waterspots.
If your family member can’t live with the swirls..... unfortunately yes, polish and re-coat.
This time teach them bettet wash technique. If there using drive through brush car washes they’ll come right back.
Welcome to AutogeekOnline! :welcome:
I coated one of my relative car with Carpro UK 3.0 coating. After 6 months, when I checked ceramic coating, I found that there are swirls marks and some water spots on coating.
Keeping a swirl-free finish swirl-free is really difficult to do. The most you can do is everything you can do and it all starts with,
Only using contaminant-free microfiber towels, wash mitts, drying towels, etc. Anything that touches the paint - if it's contaminated, the contaminants will scratch the coating. This is why I wrote this article and made the video you see here,
How, why & when to inspect your microfiber towels when detailing cars
I would say most people I meet do NOT have any protocols in place to keep their good towels, mitts and drying towels CLEAN after use. Thus they get contaminated. The contaminants so not all wash out but instead bury and lodge into the towel, mitt or drying towel and the cycle repeats.
I've been showing a super simple way to keep used towels, mitts, etc. clean until you're ready to wash and that's to have a dedicated clean bucket in your garage and keep the inside of IT clean.
Make sense?
As for water spots? This is always a tough problem for a lot of people because there is so much pollution in our water, both city water and well water. In fact, I finally wrote an article to put the focus on the root cause of water spots.
What's in the water?
I have not used this product or not used it much, don't remember?
There is this product option from CarPro and it claims to remove light defects while leaving behind SiO2 protect that you can coat over with a coating.
CarPro Essence Xtreme Gloss Enhancer 500 ml.
It might be worth a try using a soft foam polishing or finishing pad.
Thanks,
For over a decade now I've been answering questions like this by putting the question, (the equation), into EXTREME analogies. (I will make this idea an article)
Will using a one-step cleaner/wax over a ceramic coated finish ADD more ceramic coating to the finish?
The answer is "no". What's the opposite of the word ADD? Subtract.
Like others have already commented and I'll build on, ANY one-step product, cleaner/wax or cleaner/sealant or ceramic/aio - if it works at all, (that means it can remove paint), it will remove coating.
So if you want to make the paint perfect again, repeat the prep steps and re-coat. If you do not think the car owner is capable of maintaining a perfect finish, let it go. OR - simply use a one-step product and then stick a fork in it, call it done and kick it out the door.
As mentioned CarPro Essence Plus will be the option for a non-abrasive approach with a CarPro Gloss Pad. They call it a non-abrasive jeweling polish but it is more like a glaze/sealant with minor filling capabilities. It has it's limitations with filling and will leave a layer of silica behind for protection to give it some hydrophobic behavior.
CarPro Essence PLUS 250 ml
CarPro 5.5 inch Gloss Pad
Essence which Mike linked to is an abrasive finishing polish and that is going to remove the coating that is currently present or degrade it to the point that it is going to effect the long term performance. You will have to re-coat the entire panels as spot correcting and re-coating will not blend in well as the new areas will appear darker. There is no sure way to tell how much of the coating is either removed or left behind. In short anything abrasive is going to impact it or remove it. It is not that hard to remove a coating. With saying this a cleaner wax will remove the coating as well.
Finally water spot removers such as Spotless are only good if the spots are fresh. If they have been on there long then they just don't work.
yeah.. i guess its the only way.. I need to educate them more about washing methond
thanks for advices. I really appreciate.
:D
