Can I vacuum sand more effectively?
KyleBis2
Ok so here’s the situation. My Eclipse has black interior carpets, currently full of sand from previous owner. I vacuumed them once in the time I’ve had it over the past month. I sat on just the driver foot well for around an hour and still didn’t scratch the surface of sand deposits. I know there’s the method of using a sander to agitate the sand upwards but is there any way to expedite the process? It’s ok if there’s not I just want to know before I dive in today! Oh and btw the vacuum I’m currently using is the Ridgid WD4070.
A stiff brush in one hand and the vacuum in the other hand. Aggitate and follow as close as possible with the vacuum.
If you feel super ambitious you could pull the driver’s side carpet if it is segmented. Once out of the vehicle you can pressure rinse with a low pressure, wide fan tipped, pressure washer. Be careful not to get to close to the carpet as a pressure washer can add (permanent) lines to the carpet if you get too close with too much pressure.
That is where having a vacuum with a high lift rating is so important. I also think it's important for a vacuum to also do wet and not only dry (which to me is frankly useless). Hence why I still strongly suggest this one:
https://www.autogeekonline.net/foru...3-pf51-wet-dry-vac-review.html?highlight=pf51
If you were dealing with heavy built in sand/dirt in a vehicles carpet [not the matts] and removing the carpet was not an option, what would be your process in conjunction with your wet vac?
It comes with a stiff-bristled brush attachment. I would use it aggressively. I sometimes just use the hose end on its own. The handle of the hose has a pistol grip that you can work hard too.
Sent from my E6853 using Tapatalk
I haven’t found a way to make vacuuming built in sand super fast and easy... But IME these 2 attachments work better than the rest.
The Ridgid triangle stiff brush attachment.
09e0d8c3ac16d90a049d43306165368c.heic
This little gulper.
6a66f79eeb3d36b87120b11737b48051.heic
The best thing about this gulper is that it has built in stiff bristles that aren’t removable. [so you don’t have to worry about them slipping off like on other attachments]
32fda3acfa1e11567989dfce31a7ddd5.heic
I recently bought this turbo brush attachment, but based on my initial testing it seems to be pretty much useless at picking up built in sand from carpets.
af04897f6bd9cbcf4e941fc03ed03af4.heic
A plain old crevice tool [prefferably a short 1] also works great and deserves mention.
Is the handle you’re talking about sort of similar to this? I’ve always thought about buying 1 of these but wasn’t sure if it would be that useful.
Some good tips so far. I also employ the stiff brush and close follow with vac technique. Sometimes many many passes. I also beat mats with a small bat first.
Eldorado nice to see you tested one of those turbo nozzle attachement out. When it comes fine sand that penetrates the carpets deep I too don't think they are so effective. More effective to that dirt that lays on top of the carpets or just in it. When doing the fine sand that penetrates the carpets I want power from the vacuum. And those attachement you show I can see is effective to keep the power up and loosen the sand from the carpet. So OP if you have an attachement like those test them out or something like that with stiff bristles brush on it. And still have in mind to have a longer stiff bristles brush to get the deeper layering fine sand to come up to the surface of the carpet. It will be many passes on a smaller spot to get it out. And maybe when you think it's enough. After some time it comes up fine sand again. It's what to expect with the finer particals that goes so deep as to the bottom of the carpet.
i go to the dollar store and buy toilet brushes, cut the handles off and slide it into my cordless drill, then follow the spinning brush head with the vaccum, works great for pet hair as well.
Sadly its all one carpet inside. If i cant get good results, that may be an option.
Seems like it great option. I just picked up my ridgid a few months ago. It had good power and lifting capabilities but i have nothing to compare it too so im not sure on how well it works. Maybe if it craps the bed ill look into the PF51.
This little gulper.
Funny you mentioned the brush attachment, i just picked up one today. (Not the turbo brush, normal brush.) Ill give it a try!
Now that’s some originality. Props.
Like I said earlier, I’m not promising it’s gonna knock that sand out in an instant, because sand can be on a whole nother level of never ending... But as far all other car vacuuming goes, I absolutely love that attachment. For me it was a game changer. Especially when hooked up to the 2.5” hose for max power, but it also has its drawbacks i.e. when hooked up to the larger hose via the adapter, it makes a crazy loud high pitched noise that can drive you near insane. lol.
9976c5b1890e2b66417b5de8723be70c.heic
And when it’s hooked up to the Orange hose that comes in the kit, it seems more prone to slip off [friction fit]. I guess you can’t have your cake and eat it too.
A few years back I had a Dirt Devil bagless vacuum for the house that came with a turbo attachment. I also had a nubuck couch and 2 indoor cats... That attachment was perfect when it came to vacuuming cat fur off that couch, but its limitations are exactly how you describe.
This little gulper.
What brand is that handle?
