artofdetailing
- Sep 13, 2010
- 437
Will I run into problems since the temperature has dropped? I know the coating cures better with heat so I figured id ask your guys opinions
Once again, there is no miscommunication...just your misunderstanding/misapplication. It can take up to 90 depending on climate and heat exposure. The average time for this time of year in the US is 30 days give or take. There is no magic moment when it goes from not cured to cured. The cure time is determined by exposure to heat...not time.
I remember the first couple of syringes of the original Opti Coat (pro only) that I used. I swear it fully hardened in about a week. I had to use 3000 grit to remove a drop I missed and left on the fender. Both the current offerings take longer to harden now. That is a huge plus for the do it yourselfer and detailer's alike unless the customer is a polishing addict or likes to operate in test mode. For myself, I actually preferred the faster cure time.
