Can we say PP?
Castrol super clean in purple container. The stuff works even better then purple power by a large margin if you encounter heavy oil, grease just carful on certain types of aluminum
Nice one. :xyxthumbs:
Did you agitate it at all, or was that spray on, dwell and blast off?
Also are you / did you re-lubricate the hinges?
No agitation just used water hose, but I didn't know that I need to re lube the hinges oops my bad I'll do that today
Yeah, usually when using such cleaning techniques, it tends to also wash away any grease/ lube that was there previously. :)
It's not the same door. The rubber stop is on the opposite side. Assuming he did all of them, and just snapped a before/after of a random one
