You can use a white pad with KAO and have the ability to do some slight correction on softer paints. Then I would go with red, blue or grey pad with the Klasse Sealant.
You can get the application instructions at this website. Go to the store, click on either the AIO or sealant, and follow the Klasse application guide. The key to both of these products, whether applied by machine or by hand is to apply it as thin as possible.
I just applied them both today. White pad with kaio on speed 5
hand applied ksg using a pinnacle foam pad. Spritzed the ksg on the pad and scrunched to prime then applied it super thin like opticoat. Had the same kind of flashing like with OC and could work down high spots just the same. I went over it with a mf after a few panels but only really needed it for places like around door handles where I couldn't really work out the high spots.
