Good afternoon, can you clay after applying a sealant? My specific circumstance is this, about a month ago I applied wfdgps and the other day tree sap got on the car. So would I be able to clay without it being a detriment to the sealant?
I would clay and seal again. What makes you think that claying will get rid of the tree sap? I hope it does, but a light polish may be in order.
Sealant bonds to the paint. Clay removes unsmooth contaminants from the paint.
What this leads to is: some say that a light use of clay after sealant has cured (12-24 hours usually) that it will remain on the car. I feel like it probably makes it weaker, but the only way to know for sure is to try it and see if it still beads/sheets as it did before. I think it's a case by case basis, depending on how strong of a clay or sealant used, how many passes you make with they clay, and how hard you rub the clay. Might as well reseal where you clay, better to have it over than under- protected.
