I'm getting mixed information based on what I've read about clear coat.
Many threads with knowledgeable folks on AGO, even Mike himself, have said that adding clear coat to existing clear coat without being able to tell is almost impossible (e.g. burned through OEM clear coat and want to add clear coat , or just simply want more clear coat on top of OEM clear coat)
However, there have also been many threads where people have used touch-up paint (1 step, or 2 step with clear coat applied after), sanding, and polishing to fix a scratch or a keyed car with almost no sign of previous damage. In this case, the clear coat was successfully blended together through sanding and polishing to the OEM clear coat, leading me to believe that you in fact CAN touch up clear coat.
Is the difference here the size of the damage so it is more difficult to tell? I'm working on a project where I am using touch up paint for a 1/2 inch diameter damaged area that was filled with putty. I planned on leveling the putty/epoxy, hitting it with touch up paint, sand, then apply clear coat and sand/polish that. Will this work? Thinking that I was going to re-spray with clear coat anyway, I think I might have taken off most if not all of the clear coat in a small area surrounding the damaged area.
