tubbycustard
- Sep 15, 2024
- 1
For background context:
2019 S60 Volvo
Black Paint
Already fully decontaminated
Washed with dawn dish soap and clay barred to strip all previous waxes/coatings
So now the problem...
I first started out with a rotary machine which I now know is not the right tool for a beginner. I did a mix of compound/polish but mostly polish because I want to use the least aggressive method, I don't need show car quality but I also need some level of gloss. So I bought a Dual Action short throw machine. Then I stocked up on many different pads. I got some finishing/cutting pads from Walmart, one from Harbor Freight, and a full kit from SPTA that has like 5 levels of cutting. I've tried using P4 Chemical guys, Meguiars Ultimate Compound and Ultimate Polish. I gave up with P4 and have mainly been using Meg Ultimate Polish, which I tried with different levels of pads. According to Ammo NYC you should actually use a stiffer pad with a polish when dealing with holograms. So I tried that and it didn't get rid of anything. I tried the softest pad I have and that also still has these spiderweb sort of scratches. I have been keeping my work area very small and using small amounts of product relative to the area Im in. Probably like less than 8inx8in. I work it in slow speed, then go around 3.5 to 4 speed, and work the area 4-6 passes, cross hatching and the polish is almost clear by then. When I wipe off its still no better. Using an IPA wipedown makes it even worse since I think the oils from Meg is hiding more...
Ultimately I want to ceramic coat my car so I bought Carpro Eraser and Carpro Essence. Im really hoping Essence will be my hail mary and help with the mico marring. If I need to switch any products out please advise.
Below is the water spots from IPA and the plethora of micro marring. This has mostly gone away since my first day but still wanted to showcase how bad it was:
Below is the most recent pic and what I am dealing with, I cant tell if its spider webs scratches or holograms or micromarring but its all over the panel
2019 S60 Volvo
Black Paint
