Without seeing pics, we can only provide some guesses as to what is needed. A couple of items in your post might need enhancement, and I need some questions answered. You have SSR 2.5 and 1.0 correct ?? You have orange pad, what about white and grey ?? How long are you working the polish ??
Ok lets start with some suggestions .... first lets start with the white pad and some 2.5. (three stripes along the pad) Wipe the pad down the finish once, and then turn the PC on. Starting at 3000rpms. Once you get enough that it wont spit turn that puppy up to 5500rpms. Keep at each panel by panel (1/2 hood by 1/2 hood) for at least two minutes per panel. You should not stop until the polish has flash cured and is milky or cloudy. If it happens to soon, then spritz the pad with water and keep going. Wipe off with a very soft microfiber. Look at the finish .... if no swirls are present we move on. If not, we readdress the panel. (Looks better --- redo . Looks no different we move to the orange abrasive/cutting pad.)
Once we have gotten the finish to looking more than acceptable, its time to j ewel the finish. We are going to use a finishing pad and 1.0. We are going to work the polish a little longer (might also need a spritz of water if drys to quickly) and we are going to do each panel twice if necessary.
Once our polish work is done, then and only then do we seal the paint. Wax or sealant of your choice. And if you prefer not to polish as directed, then a glaze and wax with temporarily hide imperfections versus removing them.
Should you want to move to another line of polishes. Well Megs DACP, Optimum, and Menzerna would be my only suggestions. I do feel when used correctly SSR's in combo will work just as well. If your scratches are not reduced or lessened above they are definetely more than moderate and a rotary polisher will be needed. Dont know if you caught this post and video, but its a great how-to
http://www.detailcity.org/forums/de...icks-forum/17120-porter-cable-video-demo.html
