I came out this morning to seeing my SUV had been egged last night. I was leaving for work so I haven't a chance to try and clean it off yet. It's about 30F degrees where I live. Does anyone have any suggestions?
Here are a couple I "googled" this morning. Which one of these would you suggest? Or a better method if you know of any.
#1
Using your hand, remove all traces of the egg shell from the car.
Once pieces of the egg shell are removed, clean the egg and yolk from the car using a soft towel. It is important to remove all traces of the egg shell. This way, you avoid scratching the surface of the car
Create a mixture using 1 part water and 1 part vinegar.
Soak a towel in the mixture, and place it on the egg stain. You may also spray the mixture onto the car using a spray bottle. Allow the towel to sit for at least 15 minutes.
Remove the towel. Dry the area using a different towel.
Repeat if necessary
#2
Saturate the area with Isopropyl Alcohol and keep it ‘wet’ for 4-5 minutes with a soaked towel laid on the stain, do not agitate the surface.
Flush with clean water and dry thoroughly.
Inspect surface for cracking, discoloration or other damage with a 30X lighted magnifying loupe, use a chemical cleaner to remove any discoloration, and then apply a paint protection product.
If the clear coat shows signs of failure (cracking) take vehicle to a professional paint / body shop.
This sucks to say the least. I just got a new Mustang and have ran out of garage space so I have to park the SUV outside now. It only has 14K miles on it and is (was) in perfect condition. Guess I'll be getting some camera's today....
Thanks for your help.
#1
Repeat if necessary
#2
