animescreen
- Jan 16, 2008
- 288
((((I hope to get several different inputs so i can feel more safe and secure as going under a car is pretty scary!)))))
So i have questions regarding using my 3ton jack lift, 4 jackstands and tire stopper to safely and succesffully lift my car and be held by 4 jack stands so i can paint my brake calipers... Or also clean the wheel wells and remove my rims to fully clean them...
This is currently how I do it..(in my garage where its flat so no need for tire stops but i still put it in back)
Find the lift point in my car (front left tire), lift it, . put a jack stand under it... then do the same for the (right tire).. Then back left tire, and finally do the back right tire.. So questions i have are.
1. Is this ok and safe way to lift my car and be held by the jackstand?
2. How high should i have my car lifted and be held by jackstand as it's resizable..
(i'm afraid of lifting it higher then the minimum as it seems like it will slide and i get crushed etc...)
3. How long can i have the car sitting in this position with all 4 jackstands lifting the car... The G2 caliper paint im doing says it needs to dry 24 hours.
4. When i lift the car on each side.. i hear cracking or screaching sound that scares that crap out of me and seems like im breaking something... is this normal and is just shocks etc... (i am putting the lift in right area and jackstand as well...)... I never lifted all 4 tires before because of this scary sound but i will have to .... I always feel something will snap and my car will just collapse.
5. After putting my wheels back.. which jackstand should i remove first, second etc...
6. And finally i'm assuming that when lowering the car with my lift.... i should do gradual lower intsead of instantly correct?
