Hi all,
We have an 03' Nissan Pulsar (I think USA calls them Almera), it smelled a little off (mildew) One day I noticed water on the drivers-side carpet (pushed fingers into carpet, water appeared). Thinking there must be a leak and a little water got in somehow (around the middle of the carpet wasn't wet. I couldn't see anywhere that the water could have come from).
I removed the seats then the carpet so I could give it a clean, and hang on the clothes line to dry out. Well... the foam under the foot-area of the carpet was glued to both the carpet and the car body, so that was damaged during the removal, but, it was also saturated with a lot more water than I thought. When I finally got the carpet out, I could see the passenger side was a little wet too, but water was built up further back towards the centre of the car also (see pics). To my knowledge, no window was down so it must have leaked someone (perhaps even over a period of time)
I cleaned the carpet using 3D Orange Degreaser (mainly the primary dirty spots), then pressure washed it, sucked up as much as I could with my Bissell spot cleaner extracter, and hung it on the line to dry in the sun. Then I used a towel to soak up the puddles of water in the car. Once both were dry, I re-installed the carper, which smelt ok. Everything seemed ok at first, but the smell of mildew/mould has come back, specially if I rains. I go out every now and then and feel the carpet, but feels dry. I keep a cover over the front of the car until I can figure where the water came from.
Does anyone have any suggestions or experience dealing with this sort of thing? I'm thinking I'll need to remove the carpet again and perhaps cleaner the whole thing with a specific solution for mildew/mould ?? I don't have an Ozone machine. I do have an air purifier for the house though.
Any suggestions on where to look for leaks? This model has no sunroof, so there should be a drainage hose going down the pillar, right?
Pics below show the damage (mainly to the foam under the carpet)
Thanks in advance.
Thanks in advance.
