So i have a carbon fiber hood that has gotten a nasty haze on it. I have been detailing for a while and thought lets just wet sand it. so i did, i took 1500 grit sandpaper and wet sanded then buffed it out with my PC7424xp and some CG 2.0 compound.it turned out great, but only for a week and a half. then it came right back. my question is, what can i do to make it not come back? ill try and cover all the bases here. it is gel coated VIS carbon fiber hood. i did wet sand and polish is out. then applied sealant to it as well. now the haze is back. WHAT TO DO?!? its making me crazy
Are you sure the Porter Cable polisher removed 100% of the sanding marks? It's possible but usually what happens is you make the surface shiny but if look closely, you'll see there are still sanding marks or sanding scratches in the surface.
Other than that I've worked on a ton of neglected carbon fiber hoods, beside compounding, they act like single stage paints i that they really like to be polished with an oily polish like the M80 Speed Glaze, #3 Machine Glaze or #7 Show Car Glaze and then seal up the surface.
Some compounds will have a drying-out or dulling effect to the surface they are used on because they use solvents as carrying agents instead of polishing oils.
Get some M80 Speed Glaze and re-polish the hood and the seal it with a quality paint sealant. One thing for sure, you will always have to maintain it to preserve a deep, clear looking finish. Polyester Resin gel-coats are very porous and can and will dry out and oxidize very easily. Something with polishing oils will penetrate into the resin and maintain a clear, darkness, which is what you want.
See this article for some related information...
The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints
This is key...
Saturation Application --> The First Application
This is a mostly unknown technique and that is to let the first application penetrate and soak into the paint for up to 24 hours before wiping the product off. The idea being to really apply the product wet and work it in really well and the walk away.
The idea is to allow the heavy concentration of oils to penetrate and seep into the paint for maximum saturation before removing the product and continuing with the process. In this case I finished applying the first application of #7 around 9:00 pm and then left the #7 to soak in until the next day. I started wiping the product off then next morning right about 10:00am.
Some will argue if this works or not buy my experience is that with a porous single stage paint it does in fact help. One thing for sure it can't hurt.
Paper Test for Capillary Action
If you place a few drops of #7 onto a piece of paper and then monitor it over a few days you will see the oils in the #7 migrate or seep away from the actual drop of product. It does this through capillary action and the same thing can work to your car's paints' advantage if it's a single stage lacquer or enamel paint.
I placed a few drops about the size of a nickel on a piece of standard printer paper around 3:00pm.
The next day I took these pictures at approximately 10:00am, (19 hours later), note how the oils in the drops of #7 have migrated outward via
capillary action.
Feeder Oils penetrate or feed the paint
This same effect can take place in a single stage paint but not only will the oils travel horizontally, they will also travel vertically, that they will penetrate downward "into" your car's paint and this is where the term
feeder oils comes from as the oils penetrate into or feed the paint. The result is they will condition the paint restoring some level of workability as compared to just working on old dry paint, and they will also bring out the full richness of color, something that will showcase the beauty of your car's paint.
