HealthyCivic
- Jul 1, 2009
- 31
Mike, I have a question for you. How on earth do you not get carpal tunnel syndrome!?!?!? Feed back please
Detailer's and just about everyone else for that matter!
You said it!wish i was 20 again...
^Yes, this is correct, carpal tunnel surgery is usually minimally invasive because it's done laparoscopically (no scar). It has a very high rate of success as well. As Scott said, if you keep doing the same repetitive motions that caused it in the first place, a related problem can recur or pop up somewhere else in the arm, elbow, wrist, shoulder, or neck. But definitely look into the surgery sooner rather than later--it can prevent the accumulation of scar tissue in and around the tunnel. And definitely start using BOTH hands ALL the time. Conditioning (stretching + stretching + massaging) your wrists, elbows, and forearms is good prevention for carpal tunnel. (I am a doctor.)
... Conditioning (stretching + stretching + massaging) your wrists, elbows, and forearms is good prevention for carpal tunnel. (I am a doctor.)
your an md ?^Yes, this is correct, carpal tunnel surgery is usually minimally invasive because it's done laparoscopically (no scar). It has a very high rate of success as well. (I've had the surgery myself.) As Scott said, if you keep doing the same repetitive motions that caused it in the first place, a related problem can recur or pop up somewhere else in the arm, elbow, wrist, shoulder, or neck. But definitely look into the surgery sooner rather than later--it can prevent the accumulation of scar tissue in and around the tunnel. And definitely start using BOTH hands ALL the time. Conditioning (stretching + stretching + massaging) your wrists, elbows, and forearms is good prevention for carpal tunnel. (I am a doctor.)
your an md ?
Ok, Mike, we need to see what these Arm Holder Uppers look like, unless they are shoulders or chair arms...
Thanks, Mike! Do you have any other info on those, like the technical name or mfr? Or are they a custom creation of yours? I recognize that CAD Corner, too...and that's some setup with the two monitors in different orientations...
Mike Phillips said:In case you don't know, there are little tiny up and down arrow button in the upper right hand corner of your message box and if you click on the down arrow it will increase or stretch-out your message box giving you more visible working room to type in and format your message.
It looks like this:![]()
It's kind of tiny so here's a screen shot to show everyone where it's at...
