Carpet cleaning help
aaron427
What is everyone using to clean the carpets and seats? Steam cleaner or a bissell type machine? Will not see heavy use but something to spot clean with. I currently use my big one from the house and it is a pain. Thanks for the suggestions
Folex and a brush. Wipe with a towel.
Sent from my HTC Sensation using Tapatalk 2
folex or apc+ with a carpet brush for spot cleaning.
If you want to do the whole interior, get a steamer.
Ok thanks. I'll pick some of that up. What steamers should I look at? I am on a budget and most I have seen are in the 600-up range. Anything less expensive that is decent? It will see some use but not tons of it.
Shark makes one that retails around $100 but you can get a 20% discount at Bed Bath beyond. Of course it doesn't work like the more expensive models but it heats up quickly and will take tough stains out of carpet. Just requires a little more time and patience. Also great for glass.
The vapamore is $299 at AG. I am not sure if those 20% off discount code will work for machines.
The Sharks and the Wagner are around $100.
