Bullitt AK
- Jul 10, 2010
- 196
my concern is my shop vac getting damaged ...ok so im using the apc+ at 10:1 ...lightly wetting the carpet first then spraying and agitating with a brush...im supposed to run it without a filter while sucking up the water right?
it says its not recommended for use in hot water extractors because of the foam but i don't know if that's an issue with a shop vac or not...just wipe off any foam before using the vacuum on it?
