Carpet Extractor Alternatives
shoeless89
So I don't have $600+ to throw down on a more professional hot water extractor right now. I usually just vac, spray carpet cleaner, aggitate, scrub with terry cloth towel, then vac again. But I'm not really happy with the results all the time. What are my alternitives? I was looking at http://http://www.fingerhut.com/product/bissell-auto-care-proheat-portable-deep-cleaner/nb248.uts?ci_src=14110944&ci_sku=NB248&CTid=661[/URL]
I used my girlfriends one that was similar to this and it definitely helped with those really duty areas but obviously not as well as the professional one. What are your guys opinions? Maybe I could just use this until I could get the money for the Mytee Lite II?
I as well as many others use the Bissell Pro Heat. It doesn't matter which one as they are all the same. I have a refurbished one that I bought for around $40 and it works perfectly fine.
I'm using the Bissel Little Green Machine with heat till I can afford a nicer commercial one. It has impressed a number of my customers with the outcome. Proper technique is important to get good results.
I use the Little Green Machine as well and it works fine. I use any OTC carpet claener as a pre-treater, let that soak in for a few minutes and it seems to work well.
I as well use the Bissle Little Green with DP Pretreatment. Proper pretreatments will get you really good results.
I think the little green is good for anyone just starting out with a detailing biz. I use one & I like the results I get with it plus it's light weight. I believe it's all about the product you use & with a good extractor 90% of the time you'll get good results I know I have.
i have a lgm but it leaks,so i took the extractor head off and put it on my shop vac and i think it works better,just have to spray whatever you use first
I use the LGM Car Care Pro, it's the black unit. I do about 4 shampoo's a week with it. A little elbow greese along with the wet vac to suck up more of the liquid and it works jut fine until I get a pro unit. My clients seem to be happy with the results.
Most of here don't detail enough to justify spending $1200 - $1400 on a hot water extractor. Would I love to have one, of course but this is just a bit steep to justify cleaning a dozen carpets or so annually.
Carpets and floor matt's can easily be cleaned utilizing most of what you probable have already.
  • Folex Carpet Cleaner
  • Scrub Brush
  • Warm Water
  • Shop Vacuum
Folex Carpet Cleaner is available at many local stores including Lowe's....
  • Scrub Brush
  • Warm Water
  • Shop Vacuum
:goodpost:
This is how I do all my carpet details, with the exception that I use 303 Cleaner as opposed to Folex (though I hear Folex is some of the best).
:props:
I use the little green too. If the carpets were badly stained & I had to use a lot of solution, I may follow it up with a shop vac to remove excess moisture since the little green's vac isn't that great. The only thing about the little green is pacing yourself b/c the unit doesn't keep the water hot. Whatever dirt/stains the Little Green doesn't remove, I spot clean with folex. I don't know what they put in folex to make it work b/c it doesn't smell, or leave a residue but it's amazing!
Had it not been for the recent 20% off sale on everything on AG I would probably be using a couple of bissels and an assortment of carpet/upholstery cleaners. I had done a few really bad interiors with just a shop-vac, towels/rags, hot water in spray bottles(most won't last with too hot of water), WG Spot Elim. and Upholstery&Carpet, and DP extractor pre-treatment. While I got above average results and better than I have seen some people get with actual extractor like LGM, it took way to long to keep doing it that way. The Aztec I have now made quick of work of tough jobs since since I have had it. While it has not quite paid for itself yet(depending what I say is paid off from my profits so far), I hope to get rolling on interior work soon to make it really worth having around. I was going to buy a refurbished Bissel LGM from a local bargain outlet(Ollies) as it was only like $60, but realized my Aztec didn't need a companion.lol
The keys to cleaning carpet and upholstery stains is early removal. It that's not an option as with vehicles that are not your own then a thorough vacuuming and a pretreatment are in order. Follow the recommendations for the pretreatment product by allowing the chemical to dwell for several minutes. I then hit the pretreated area with hot water to further activate the chemicals and gently scrub the area as to agitate, not to push the stain back into the carpet/uphlst. Allow the area to sit another few minutes then blot the area with a terry towel to remove the stain/dirt particles from the surface. Follow the blotting with a thorough vacuuming to remove the moisture. Allow the are to dry before attempting to clean again; this allows you too see actual results when dry and allows residual chemicals, stain and dirt to wick to the surface to and be dry vacuumed away before doing another wet treatment. This practice works especially well on berber carpets or anything similar to berber with a tight wound fiber/yarn. With upholstery and tight wound carpet fibers it is best to use a minimal amount of cleaning agent/chemicals and preferably with low/no foaming agents and fragrances in them, i.e. 303 carpet/fabric cleaner, folex, DP extractor pretreatment, and/or vinegar. In most cases the best method with carpet/upholstery like stated is to dry clean(vacuuming and brushing), misting the area with a cleaner like stated, then lightly spray with hot water, a few minutes dwell time, then blot to remove majority of stain and chems, follow w/ vac. If an area has been previously treated with chemicals and is still stained then do the following method with out applying another chemical. This is highly recommended for a berber carpet(which I recently cleaned in a home and a car's floor mats). Hope this was helpful and not more than what this thread was asking. Just passing on info that has worked for me.
Like boby say's. If you don't have that much work. Go with something like the bissel.
But if you have enough detail's. Then go for a portable extractor with heater. You'll see the result's and time saving.
A lot of guy's forget the principal step. In a carpet cleaning
that is. Vaccum the carpet. That's the first step
the second one. Is giving at least 5 to 10mn. To your cleaner.so it can work better
then it comes the nice / brush
follow by the extraction with hot water
you will see the difference
Extraction / deep extraction is the best key. The help of the in line heater in your portable. Makes the difference
i do comercial & residential carpet cleaning. As well ofcourse auto detail. My strong side in auto detail. Is the interior.
I have use a lot of different cleaning product's / some top of the line, and use the regular kind
for me the best option is the help of the hot water / the psi that a nice portable give's you. And ofcourse the extraction power.
Don't get me wrong. But for me rag's & vaccum alone. Does not stand the chance & the result's as the portable does.
Even if you use a nice cleaner. The old stains. The old cleaner that most of the people use to do it them self. Before calling some one to do it for them. Plus your new cleaner. With just vaccum, rag's and brush. You are leaving behind all that mixture.
This is my opinion
