Joseph Rogers
- Apr 23, 2014
- 59
I'm a floor guy looking at adding detailing as a service. Saw a video where he sprayed some really foamy stuff onto a floormat, worked it in with a brush, and then wiped with a twisting motion using a MF towel.
Is this a normal, accepted method of cleaning it? Can someone talk to me about the chemistry of the standard interior carpet cleaner for vehicles?
In carpet cleaning, there's this big fuss about "shampooing" which is where you use lots of foam to bring the dirt to the surface. It's not considered to be as good as Hot Water Extraction (HWE), where you spray and extract with water. There's also a method called encapsulation, where you spray something down, scrub it until a light foam appears, and this cleaning agent is formulated to break soil loose. It has a crystallizing agent that will form a barrier around the soiling as it dries, keeping it from re-attaching to the carpet fiber, and the next time it's vacuumed, voila! This method can be boosted by scrubbing with various types of fiber pads to "pick up" dirt with the pad.
The video I saw is most similar to the last technique I listed, called "padcapping", but I much prefer HWE for cleaning. The result I get can be pretty impressive. Wondering if this can be applied to vehicles profitably, if it's a normal practice in the industry, etc...
