Nick McKees37
McKee's 37 Product Support
- Jan 6, 2011
- 7,265
Every single month I eagerly await the arrival of the latest issue of Car and Driver, which is by far my favorite automotive publication. It generally arrives at Autogeek on the 1st or the 2nd of every month. Sometimes I simply can't wait so I'll head up to the local book store towards the end of the month hoping that a careless employee didn't follow the embargo and accidentally put next month's issue out early. It's kind of exciting because when that happens, I get to read about the newest SL63 AMG or see spy shots of the 2014 Corvette before anyone else.
The same thing can be said for working at Autogeek and getting to test out the latest and greatest car care products before anyone else gets their hands on 'em. Sure, getting to test a new product before everyone else is neat, but what's even better is that I get to write about it. The key word is write, not brag. Don't get frustrated just yet, as I only show off products that are in stock so feel free to click "add to cart" after reading about the latest and greatest product from CarPro Innovative Nano Coats in this review.
CarPro Dlux Coating
Dlux, the newest car care product from CarPro, is a semi-permanent coating designed to restore, protect and enhance all exterior plastic and rubber surfaces. Plastic and rubber surfaces treated with Dlux will retain their factory appearance wash after wash. What the original Cquartz did for your vehicle's paint, Cquartz Dlux will do for your vehicle's exterior plastic and rubber surfaces.
This is what the front bumper plastic trim looks like on your typical daily driver. Dull, faded and lifeless. Cquartz Dlux will inject new life into this plastic trim in a couple simple steps.
In order for Cquartz Dlux to form a strong bond to the surface, it should be thoroughly cleaned first with a plastic-friendly all purpose cleaner or degreaser. I've found that Detailer's Cleanse-All Exterior Cleaner is ideal for use before applying trim restorers as it deeply cleans the surface. Spray on, let it sit for a minute, and wipe off using a microfiber towel.
What's included:
Cquartz Dlux includes a blue sponge applicator and four suede microfiber cloths. Simply wrap one of the supplied suede microfiber cloths around the blue sponge applicator and you're ready to apply Cquartz Dlux.
Cquartz Dlux is designed to be applied thin. To say a little bit goes a long way is an understatement.
Application is simple:
Wipe on desired surface in straight line motions, slightly overlapping each time. Reapply as needed.
50/50:
Cquartz Dlux restores a like-new factory appearance to exterior plastic and rubber surfaces. It's not greasy, it dries to the touch, and it has no sheen.
Finished:
Give your vehicle's exterior plastic and rubber trim a like-new, factory appearance with CarPro's latest innovation, Cquartz Dlux.
CQuartz DLux Coating
