Carpro CQuartz UK 3.0 and Gliss version 2
Reuben Brumby
I just applied 1 layer of UK 3.0 and found a high spot. Should I polish off reapply to spot? Should I add a second layer of 3.0?
I have yet to apply gliss.
Sent from my SM-N950U using Autogeekonline mobile app
I would lightly polish and reapply the coating on that panel.
Yes polish off whole panel, re apply. I tried topping and redoing a section and none of that work.
For whatever chemical reasons, CQuartz UK, UK3.0, Classic and TI02 will not blend well on spot repairs. Un-like its bigger brothers, CQuartz Pro and Finest Reserve. They both blend in very well on repair work.
i found cquartz classic to darken areas it was applied to so if you went a little over a panel into the next, it would darken that to where you would then have to coat that panel or it will stand out. also seemed like gliss did the same so if you are running out of material probably best to tape off near adjacent panel or something.
