Thanks for all of the advice. I am aware and willing to take the time to detail / polish the car out before it is done. Right now I have Menzerna SIP, Menzerna SuperFinish, and Menzerna Finishing Glaze, (PO115C), would the Reflect polish be redundant? I am already getting Eraser, Reload, Iron-X, the applicators and the microfiber cloths. Anything redundant or that I am missing?
If you're saying you have Menzerna "Super Finish", and that product is actually SF-4000, then I would say you're Golden! At least for a product that will Amp Gloss to as best as it can get....provided that your DA Polisher, your proper selection of Polishing Pads, and Techniques are up to the task?
Lighting is very critical. If you cannot see what you are doing, all will be for naught.
It is both important for the final examination of your paint, and helps a whole lot when laying down a coat of the CQuartz Coating. Nor, without good lighting, you might see an area with a sleek or two you missed. Meaning that continued polishing would have gotten these out with more time, and critical inspection.
Sometimes this can be hard, you've been working all day, and want to be rewarded. The ole "Rome wasn't Built in a Day" applies. Take your time, perfect the paint, then you'll be finally ready for the "Icing on the Cake"!
CQuartz UK is basically not a very hard product at all to apply, provided to keep in mind the basic guidelines, temps applied, applied to paint that isn't still protected by some other durable sealant-wax, and applying and wiping within the proper time frame.
I slapped UK on my Tahoe last fall. This stuff went on like a coat of glass, spread easily, leveled pretty much instantly, and really almost didn't even need to come behind with a MF Towel to wipe to level possible high spots. The lighting was a precaution, an initial worry of how the product would behave, but it behaved extremely well. The lighting will perhaps help insure you have complete coverage on any panel you are applying to.
Take one panel at a time. Do not move on with further application until you are 100% happy that that panel looks great. Then move to the next around the vehicle.
The Roof is one logical choice besides the hood to start on. I like working my way down, most people do. Hood, Roof, Trunk. Then each side.
Have a couple very soft MF's for the wipe after application.
After that, and all is applied, step back, admire, but don't touch! Leave it alone for at least a good hour, and 2-3 might even be better if you have a garage.
Then you can come behind, and lovingly apply a nice layer of CP Reload! You will be very happy! I was, and still am!
