CarPro Eraser before or after Polish?
RFulmer
Should I use CarPro Eraser before or after I polish?
after...its made to remove the left over oils the polish leaves behind your towel doesnt remove.
Or occasionally during polishing if you want to check the finish to be sure you are leaving no marring or holograms that the polishing oils are hiding.
Thanks!!! Let the work begin (off to the garage).
